Since I've got a couple of days before it's delivered I'm just thinking over the install. Sound input is easy enough, I'll splice off the rear speaker cables back into the boot (which the instructions allow for, so no need for a converter apparently) The two things I'm not so confident with is the power supply and/or the remote switching. Should I tap into the headunit power wires to power the sub too? Is there anything else I should be aware of?
Here's the wiring diagram in the instructions.
I noticed on one online source that the positive power wire is a 'terminal 30' which apparently is a constant, unswitched live, so to tap off these would actually be a constant power draw when the key is taken out. If that's the case then where would I find an ignition switched live?
