The unit refuses to play a DVD , even original DVD doesnt work. The deck plays a normal CD disk 100% but when I try to play a DVD it says disk read error. I tried to search the net but to no avail
I think it has to do with a area restriction or something , otherwise it would not have played a normal CD not true ?? I did reset the unit on the front panel but still no luck.
When I press the off button once it goes into a sleep mode thingy amd from there I can access a dvd setup menu , I can change the area code from USA ( default ) but when I change it , it requires an area code , now what code to put in here
If anyone has some info or advise for me I would kindly appreciate it
