UK-POLOS.NET - THE VW Polo Forum • Coolant leak 1.4se
Coolant leak 1.4se
Posted: Wed May 22, 2013 9:43 pm
by Richn83
I've had the car for a month now and have had to put a litres of coolant in, there is a small puddle in the drive in front of driver side front wheel but when underneath no sign of leak from that area but some liquid around back of the engine.
Has anyone else had any coolant issues as can't find any threads.
Might also be unrelated but has anyone heard a low volume beep when the bonnet is open, rather intermittent but regularly there?
Any comments welcome, have no codes on VCS BTW.
Re: Coolant leak 1.4se
Posted: Tue May 28, 2013 10:59 pm
by mattymdm
Suspect faulty water pump.
Posted: Wed May 29, 2013 10:12 am
by ubiquitous-j
Hi, I had the same problem with my Ibiza (6J 1.4 85PS) http://www.seatcupra.net/forums/showthread.php?t=335878
It turned out to be caused by a radiator leak. This is apparently quite a common problem and VW generally offer a goodwill gesture to cover some of the cost if you are outside of warranty.
Posted: Wed May 29, 2013 1:16 pm
by NMavs
Had a new radiator fitted to my MY11 GTI last month mate. Car only done 24,000 and managed to empty the coolant tank in under 5 miles :shock: VW replaced it under warrenty, however they did at first try to play the blame game as the car was 'substantially lower' than standard :D
