No boost
Re: No boost
Nope no smoke, I plugged it into solus in work and had the fault code p1152 which is saying its too lean which suggests a split pipe, sprayed brake cleaner everywhere and couldn't find anything, cleared the code, test drive it spluttered the took off like normal and has been ok since. Must be a bit of sh*t somewhere?
Re: No boost
has the fuel filter been replaced recently?
