Right I'm a little stuck, fully aware that it somehow twists, but I can't for the life of me get the badge to twist to remove it! I know there's threads everywhere about this but the only thing says to twist it and it just pops out!
Do you need to do anything else or is it simply a case of twist & pull? Thanks!
Removing front badge?
Re: Removing front badge?
It is just twist and pull mate, it does take a bit of doing and I had to push on it a bit to get it to come off. It only twists about an inch or so. Good luck with it
benjamin wrote:It is just twist and pull mate, it does take a bit of doing and I had to push on it a bit to get it to come off. It only twists about an inch or so. Good luck with it
So annoyed with it ! Does it remove like from the front of the grille or the back of it? If that makes sense, not sure of which way to pull!
I feel so stupid asking how to remove a badge haha!
