Change immobiliser code thru vcds
Can this be done as the theif still has my key
Re: Change immobiliser code thru vcds
I don't think that you can simply change your immobiliser code. You can do it so that the key that the thief has won't be recognised though. You'll have to wipe all the existing keys and then re match the one you have with it. -- http://www.ross-tech.com/vag-com/cars/I ... ching.html
Expensive, but if I were you i'd look in to getting the locks done.
Pleased that you got it back! There's some horrible scum bags about. Trust no one when selling a car.
My pal worked for verve he can recode them happydays untill i get new barrels priced up
