9n suspension
Request Polo related stuff! - Threads Automatically Deleted if no reply within 28 days. BUMP once every 14 days if necessary.
onlydiesels
9n suspension
Post by onlydiesels »
set of uprated/lowered suspension to suit tdi...no coilovers...pm or 07830464506
RITCHAT
Re: 9n suspension
Post by RITCHAT »
I have gti 9n3 suspension as in the lowering springs suitable for tdi as I am using a set on mine right now. drops the car by 15mm and tightens everything up in general £50
onlydiesels
Re: 9n suspension
ok,is that just springs then or dampers too...?
if its dampers too,then any chance of a contact no. and I`ll give you a bell.
RITCHAT
Re: 9n suspension
Post by RITCHAT »
I do have the rear dampers but all you do is change the springs the dampers are the same the rear is just a case of taking the bottom bolt out of the suspension and use a jack to gently lower the suspension to take the spring out and replace with the new one and repeat for the other side. The front is a bit more involved and you will need spring compressors but you could do the lot in one afternoon
onlydiesels
Re: 9n suspension
oh yeh I know this..I've got a tdi 1.9 sport and the front dampers are shot,and a rear spring has snapped so thought that if anyone had a comp. set,then I could just do a complete change...cheers for the help anyway.
RITCHAT
Re: 9n suspension
Post by RITCHAT »
no probs mate
onlydiesels
Re: 9n suspension
all sorted now..thanks to a bargain buy from kc..cheers. :D
