9n suspension
Posted: Sat Jun 22, 2013 3:15 pm
by onlydiesels
set of uprated/lowered suspension to suit tdi...no coilovers...pm or 07830464506
Re: 9n suspension
Posted: Sat Jun 22, 2013 4:56 pm
by RITCHAT
I have gti 9n3 suspension as in the lowering springs suitable for tdi as I am using a set on mine right now. drops the car by 15mm and tightens everything up in general £50
Re: 9n suspension
Posted: Sat Jun 22, 2013 6:59 pm
by onlydiesels
ok,is that just springs then or dampers too...?
if its dampers too,then any chance of a contact no. and I`ll give you a bell.
Re: 9n suspension
Posted: Sat Jun 22, 2013 8:02 pm
by RITCHAT
I do have the rear dampers but all you do is change the springs the dampers are the same the rear is just a case of taking the bottom bolt out of the suspension and use a jack to gently lower the suspension to take the spring out and replace with the new one and repeat for the other side. The front is a bit more involved and you will need spring compressors but you could do the lot in one afternoon
Re: 9n suspension
Posted: Sat Jun 22, 2013 8:19 pm
by onlydiesels
oh yeh I know this..I've got a tdi 1.9 sport and the front dampers are shot,and a rear spring has snapped so thought that if anyone had a comp. set,then I could just do a complete change...cheers for the help anyway.
Re: 9n suspension
Posted: Sat Jun 22, 2013 9:06 pm
by RITCHAT
no probs mate
Re: 9n suspension
Posted: Sun Jun 30, 2013 11:44 am
by onlydiesels
all sorted now..thanks to a bargain buy from kc..cheers. :D
