My sister has one and its misbaheving in 1st and 2nd gear. Cant get a good description of the problem, but it appears to not want to go, ie big hesitation. The other day she said she took her foot off the gas and it was still going!
My thoughts were throttle pos sensor or an ECU problem. Just wondering if anyone else has had this?
Its still under warranty but VW dont seem to be able to fix it.
MB
GTi problem - any ideas?
Hi Mark, and Welcome!
I'm not a big techie, but what strikes me as odd is that the problem only appears with first and second gear. I mean, if it were just a problem with low revs, than you'd find it in the other gears as well.
Another thing, doesn't the Gti have e-gas? As in, the throttle is controlled by the ECU? If so, the ECU is a primary suspect, right? Still weird that VW can't find the problem.
Wild guess to finish: Perhaps the throttle body is filthy?
Scooby Mark
