Gearbox!
James.watts95
Gearbox!
Will a mpi gearbox fit the polo Gti lump????
Re: Gearbox!
Yes, but the ratios are no where near correct for the 1.6, plus theres no guarantee itll handle over 5x the torque
You really need a GTI box.
James.watts95
Re: Gearbox!
ok thanks, im looking to do an engine conversion but the car has a leaky box, so was planning to change it after running 1.0 box, also if i change whole interior loom will it just be straight fit? also could i just do engine loom?
Re: Gearbox!
You should be able to just do engine loom
You would honestly be best to replace the leaking seals and use the GTI box. Using the mpi box isn't a good idea at all.
