Fluid level problems
Lukeygower
Post by Lukeygower »
After getting my car mapped it hit a fiew problems witch turnt out to be the pipe that runs from the brake filling point to the bulk head. I changed this pipe and gave it a quick bleed. I then went out to nurburgring over the weekend and the fluid level had dropped right down again, so i filled it back up and checked again today and its down again. Could all this fluid that is dissapearing be to the system not being blead properly ??.
Sent from my GT-I9300 using Tapatalk 2
Re: Fluid level problems
I would say it's not bled properly
Do a full bleed via the pressure method. That should sort it.
Lukeygower
Ill give it a go this weekend and see if it sorts the problem
