I want to add fog lamps for my polo 6r
Hello,
I have polo 6r and I want to add fog lamps.
I want to buy this: http://www.ebay.com/itm/150779414644?ss ... 1438.l2649
But I am not sure what else I need to get so that the fog lamps work for me.
I have a light switch like that: http://up389.siz.co.il/up1/zuzjqtznymyt.jpg
It dont have a option for front fog lamps like this: http://www.motorbeam.com/wp-content/upl ... Switch.jpg
(The switch I have now is have only option for rear fog lamps)
So my question is what I need to do to get the fog lamps work?
I guess I need to get a light switch with front fog lamps option.
What else? What about wiring?
Thanks alot!
Thanks alot!
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Re: I want to add fog lamps for my polo 6r
It's actually pretty simple...
You need the foglights and trim like you found on ebay.
Then you need the switch with both rear and front foglights. (Make sure you get the right one with the big 20 pin plug on the back. not with the small 10 pin plug)
And then you need the wiring loom for them. Kufatec has this loom. http://www.kufatec.co.uk/shop/en/volksw ... ction_ms=1
Then it's a case of getting the wires frm the foglights through the firewall and hook it up to fuse 54 and there is another wire in the kit from fuse 54 to the switch. (pin 9 I think) And job done.
Excellent Mart!n, to ensure:
Pin 8 front fog lights NL
Pin 9 rear fog light NSL
http://www.passatplus.de/umbauteile/ste ... 972999.jpg
To switch lights, "for example":
http://www.ebay.com/itm/For-VW-Golf-Jet ... 1a&vxp=mtr
- Mart!n-GTI-DK
Number 8 is right.
Gotta get around to fitting it myself... Had it lying around for a few weeks now.
Hey mates!
Thank for answering mart!n and ciclo
About the light switch, is this will be good?
http://www.ebay.co.uk/itm/GENUINE-3BD-9 ... 2582a38d21
Mart!n, on the link you posted here there is 2 versions (or options) on the site:
"without cornering" or "with cornering light". What is the differences? What should I choose?
More question, there is a note says "Vehicle requires coding after installation".
What coding I need to do? I have no idea in VAG-COM and dont have any tools for that..
Is coding is really required?
You say it just plug&play?
Just for be sure, fix me if I am wrong:
1. assemble the fog lights in the bumper
2. plug the wires to the fog lamps
3. plug one connector to fuse 54, the other side to pin 8 on the switch light
And then fog lamps should work?
By the way, my Polo is trendline. So I am pretty sure that I have the most basic BCM.
Greeting, iGold.
Greeting, iGold.
- Mart!n-GTI-DK
The Auto function won't work on the Polo, because there is much more required for it to work than just the lightswitch. So it wouldn't make sense to buy that one.iGold wrote:Hey mates!
Thank for answering mart!n and ciclo![]()
But other that that it will work for the functions you need.
You should pick the one without conering light. It's a much more difficult and expensive process to get conering lights to work. Would require a new BCM which will set you back a few hundred quit...iGold wrote:Mart!n, on the link you posted here there is 2 versions (or options) on the site:
There is no coding involved... Must be for the cornering lights. But again that is an expensive option to get those to work.iGold wrote:More question, there is a note says "Vehicle requires coding after installation".
Greeting, iGold.
I checked it out, this switch isnt includes the auto option. (for some reason they put a photo with a auto option)
I dont want the cornering option.
So there will be no problem if I have the most basic BCM? (trendline as I mentioned before)
It just to plug the wires as you said before and it should work?
PS,
What is the most cheap store that I can buy those parts online? (OEM parts is prefered)
28.5 USD is good price for OEM switch?
There is a cheaper option istead the wiring you posted here? (I think 34,99 £ for the wiring is a little expensive)
Thank you a lot for answering!
PS,
How can I get the BCM reference number?
And I'd be happy if you answer my previous questions
You can see the reference number bcm in two ways, by vcds or physically.
A link for you to know where is the number.
http://www.carsystems.pl/polo-central-e ... id539.html
A video for you to know where the BCM. Not mine.
https://www.youtube*.com/watch?v=9yagbbCL ... r_embedded
With all the information that has been posted here can install fog lights on your vw polo trendline.
Looking for cheaper prices on ebay or aliexpress. I personally do not seem expensive kufatec wires (already made), ask the dealer (wires, connectors, pins, tape ...)
When you know the reference number of your bcm can ask if you have any doubt.
hi i am from mexico df
Greetings to all
I have a question about this item
,my polo dont have front fog ligths of factory,so buy this article on ebay http://www.ebay.com/itm/130704701989?it ... 23&vxp=mtr, so i dont know understand how to connect cables, for example the kit comes with a very thin white cord, and do not know where it is connected.....
, also do not like putting the fuse 54 as it has no wiring,I want as much as oem but not connect
My bcm is 6r0937087m of factory
someone could help me with photos attached as would this kit please
Greetings from Mexico very good forum
Greetings to all
m7jgp
- Drives: 2011 polo 6r 1.2
hi, just fitted the front fog lights to the wifes polo
i used genuine lights and surrounds off ebay
bought the kufatek wiring harness
bought the genuine light switch again from e bay
connected short wire from fuse 54 to lighting switch pin 8
all fitted except how on earth do i get the single wire that goes to fuse 54 through the bulkhead/firewall
otherwise its complete can someone show me please with pics,
ive been upside down on me back in the drivers footwell looking for the cable i thought i had pushed through by the side of a large cable,
but gave up,
please thanks
but gave up,
please thanks
Mart!n-GTI-DK wrote:The Auto function won't work on the Polo, because there is much more required for it to work than just the lightswitch. So it wouldn't make sense to buy that one.iGold wrote:Hey mates!
But other that that it will work for the functions you need.But I woul find one wthout the AUTO.
Greeting, iGold.
Hello!
Do you know Is the installation same on 6C as on 6R model?
I have original DRL but no fog lights on my 6C.
Greetings from Finland!
