ABS problem on 6n2 Polo GTI
frankoni
Post by frankoni »
Hi all, I've just got my Polo GTI on the road ,all is great until I press on the brakes, the abs seems to cut in every other time I press the brakes. I don't have any abs lights on the dash. I've had my gearbox rebuilt so could possibly be a problem with the front sensors....or could this be a problem with the abs module ???? Has anyone else had this problem ??
Frank
Re: ABS problem on 6n2 Polo GTI
Need to get the car scanned really. Sounds like a sensor fault, or an ABS module fault.
frankoni
Post by frankoni »
Cheers for the reply, when you say get it scanned do you mean take it to a main dealer or will one of those cheap fault code readers do the job ? I don't have the engine management light or ABS light on will this make any difference trying to find a fault ?
frankoni
Post by frankoni »
I decided to bite the bullet and buy Vag-com, after scanning no fault codes were found. I tested the wheel sensors while driving and they seem ok, does this mean the ABS pump module needs re-soldering ????
I dont think the problem you are having is due to the solder joint failing - the ABS wouldnt work at all if this was the case
