Wheel Offset - ET 38 on a 6r gti
funlovincriminal
Drives: 6R GTI
Post by funlovincriminal »
Can anyone help,
I'm planning on buying some Mk1 Leon starfish alloys for the Polo to use as winters, (Weird choice I know) on my Polo 6R gti?
They are exactly the same size as the Standard Monza gti alloys, BUT, they have a 38 offset compared to polo's 46.
This means they will have +8mm poke, but How do i know if this is acceptable?
http://www.willtheyfit.com/index.php?wi ... mit=Submit
Existing & proposed Wheel Size details below
SEAT LEON 1M 98-06, 17 INCH ALLOY WHEEL, 5 TWIN STARFISH SPOKE, 5 STUD, 100PCD 7x17, OFFSET : ET38, SPEEDLINE, PART NUMBER : 1H0601025J
Polo 6r Monza
Part Number: 6R0601025H
ET46
7x17J H2
5x100
5 Stud
polodave
Re: Wheel Offset - ET 38 on a 6r gti
Post by polodave »
My summer setup is 18x9 ET30, rear wheels are 50mm wider than yours, (and stick out 41mm more than stock wheels) and I have no problems so you should be fine ;)
ben4012
Post by ben4012 »
Good puzzle. No definite answer but:
Do you know of any GTI running 10mm spacers? Do they have any problems?
Could you measure outwards from the existing tyre and make a comparison.
A small amount of stretch would solve any issues too.
funlovincriminal
Drives: 6R GTI
Thanks for that,
I would measure the tyre, but I don't have the car yet, it will be delivered mid November I think, but want to have my Winter setup ready to put straight on.
If polodave is not having any issues with a 9j et 30 wheel I think I will just go ahead & buy them. -
I can't find anywhere on the Internet where Leon wheels have been put on a polo 6R
Now to get some winter tyres, 215 / 40 / 17 - This is going to be expensive.
Nankangs are £62 each, but the mid range ones are all over £100 a corner. I've been talked out of Nankangs, but suppose they are right unfortunately, why put cheap tyres on a £20k car!
