Looking for active users as all other ones seem to have gone dead!
I need my code and if anyone has the softwear it will be brilliant and I will try and help them as much as I can!!
Radio codes - need active users
Re: Radio codes - need active users
What radio unit is it?
Rcd 200 I believe pal
Will see if I can decode it
You ledgend what do you need?
Is the radio still fitted to the car or removed?
If its the original radio, it should just work - just turn on the ignition, then turn on the radio and the safe will change to LEARN
It is the normal radio from vw
It's out the car at the moment
It said safe and I pressed something so now it's says 2 safe
I know that's means I'm on my second guess
What's the part number for it?
I plugged it in and after about 45 mins to a hour it worked haha!!
