57mpg to 32mpg
57mpg to 32mpg
Hi
When I got my car second hand from Huddersfield VW, on way home i was doing 80mph down the A12 getting 57mpg. Now if i do 80mph, i get 32mpg
Would this be because it needs a service? Or is there something else?
Re: 57mpg to 32mpg
I wouldnt rely on the dash readout. Not accurate in the slightest.
john.p.clegg
Re: 57mpg to 32mpg
I just hope plod is not reading this....sounds like a confession...
John
John
Re: 57mpg to 32mpg
What engine? The tdis suffer from egr issues causing low mpg
57mpg to 32mpg
I have the 1.2 TSI
Also, ive gone from £25 = 250 miles to £25 = 200 miles.
Just wondering if its because its due a service?
Re: 57mpg to 32mpg
Have you recently had new tyres fitted?
57mpg to 32mpg
Nope same tyres since i got the car in May 2013.
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Re: 57mpg to 32mpg
It's not uncommon that the mpg's drop when it's cold...
vc-10
- Drives: 2019 Seat Ibiza 1.0 TSI Xcellence Lux
Re: 57mpg to 32mpg
Check the tyre pressures too. If they're low it causes more resistance as the tyre deforms more. Not good for the tyre either!
57mpg to 32mpg
Hmm ill have a look. Thanks for the answers guys!
john.p.clegg
Re: 57mpg to 32mpg
Martin
"It's not uncommon that the mpg's drop when it's cold..."after the disaster of my wishbone bushes, my MPG reduced from 40 to 35 and I thought proper bushes/new tyres and tracking would sort it,but,the last tankful still gave 35 mpg....now my understanding of it is that the Lambda sensor gives info to the engine management unit to correct the air/fuel mixture..the air when colder is denser so one needs more fuel..but no extra power is needed if driven the same way,so less throttle... so why "It's not uncommon that the mpg's drop when it's cold..."
John
John
Re: 57mpg to 32mpg
engines take much longer to get to their most efficientjohn.p.clegg wrote:Martin
John
Re: 57mpg to 32mpg
Exactly, if anyone is brave/stupid enough, try switching the fan or A/C off a cold morning until you think the car engine is warm/hot - maybe two miles, then switch fan or A/C back on, at the end of that journey you should expect a substantial improvement in that journey's MPG over same journey/conditions with the fan or A/C running from engine start. I live up North and I've been doing that while using my daughter's 6J Ibiza - just to boast about the MPG that I can get on my commute to work.rover220 wrote:engines take much longer to get to their most efficient
