Wing mirror cap removal
helloimjammie
Post by helloimjammie »
Hello
Just wondering if anyone has successfully removed the mirror caps off the Polo 6r?
Wanting to just plastidip them black (removing them to make the cleanup process less hassle) and them if I liked it eventually gloss black vinyl wrap them
If any can enlighten me that'll be great :)
Jamie
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Re: Wing mirror cap removal
Post by Mart!n-GTI-DK »
First remove the glass:
Then you can remove the cap:
helloimjammie
Mart!n-GTI-DK wrote:First remove the glass:
Thank you very much for that!
Can I ask where do you find all these diagrams? I see you always post them to help people :)
Do you reckon with even pressure I wouldn't need the tool I could just use my hand?
jammydodger
Drives: 6R GTI
Post by jammydodger »
If you force it you will crack it very easily. If you don't have the tool, use a ruler like I did, move it so it's facing downward as much as possible using the mirror switch and then gently pry it out, then undo the clips like in the image and it should come off easily. Remember when putting it back on to push the clips on or it won't stay in place properly.
helloimjammie
jammydodger wrote:If you force it you will crack it very easily. If you don't have the tool, use a ruler like I did, move it so it's facing downward as much as possible using the mirror switch and then gently pry it out, then undo the clips like in the image and it should come off easily. Remember when putting it back on to push the clips on or it won't stay in place properly.
Oh okay then mate :)
What kind of ruler did you use just a plastic one or a metal one with cloth over it?
Sent from my iPad using Tapatalk
jammydodger
Drives: 6R GTI
Just a standard plastic ruler with some cloth around it to avoid damaging the heating function, I would abound the metal one to be host as it doesn't have as much give.
helloimjammie
jammydodger wrote:Just a standard plastic ruler with some cloth around it to avoid damaging the heating function, I would abound the metal one to be host as it doesn't have as much give.
Okay then mate thanks for the advice :)
Mart!n-GTI-DK
helloimjammie wrote:Can I ask where do you find all these diagrams? I see you always post them to help people :)
Sure you can. :)
Right here :)
helloimjammie
Sure you can. :)
Right here :)
Brilliant! Thanks
