VCD ISSUE NOT WORKING :( HELP ?
tommytse22
Drives: polo gti
Post by tommytse22 »
Hello! i recently got a VCD 12.12 CABLE from ebay for my Polo GTI only just got around playing with it! its not a genuine cable but it comes with VCDS 12.12 or below any version on a CD but im having issue with it, i want to do the following tweets
XDS and braking force set to 2: i cant work out how to do it! i search the web went to the drop down menu but dont see XDS and braking force
big digital mph DONE!
fogs as cornering lights: cant access cental covenience is it because i have a fake cable ?!
seat beat warming DONE!
gauge sweep wont let me pick staging ? i have a 2013 plate POLO GTI with CTHE egnine!
automatic closing windows when locking doors: cant accesscental covenience is this because i have a fake cable ?!
1 click unlock all dors selective unlocking: cant access cental covenience is this because i have a fake cable ?!
does anyone know what seem to be the problem ?
thank you!
Re: VCD ISSUE NOT WORKING :( HELP ?
Yourself answer your questions. "The cable is not genuine"
Many copies are not stable and they produces failure in reading of the units.
Try to do an auto scan with the car to the idling. (once or twice at least) :)
Post an auto scan to help you more easily. If possible.
indicator celebration
tommytse22
Drives: polo gti
Thanks ciclo! The indicator celebration work!
I will get a auto scan for you soon! When I got time to upload it! I can do nearly everything but some :( it's annoying!
tommytse22
Drives: polo gti
not sure is it because im stupid or its just the cable
tommytse22
Drives: polo gti
messaged you my auto scan! i also message the ebay seller they said everything should work as it is! he has sold loads and no one has said any thing back to him he is more then happy for me to send back to him it cost me £40 so i dont know to send back or keep for fault finding :/
First BCM:
09 Cent. Elect. ----- coding 07 ---- copy and paste New coding in this way:
Your Current coding:
25B42B3F08E12400923808002D2B0CD00040410F60060000200020000000
New coding:
3CB42BBF08E12400923808006D2B0CD00040410F60860000200020000000
Includes all the changes you mention in your first message for BCM.
Tell us the results.
I have doubts with your fog lights.
Where are DRL on your GTI? ¿Headlights or additional lamp in fog lights?
Show me a picture of your fuse box.
Later we see ABS Brakes.
Component: ESP9.0i front H02 0002
UDS Adaptation
Panel drop-down.... Expanded electronic differential lock.
tommytse22
Drives: polo gti
Thanks cicle so if I copy that code it will do all the things I mention above for my polo gti ?
Also this sounds so should but Expanded electronic differential lock is the same as extrinsic differential lock ? But renamed ? And it only let me change to strong not number 2? So I didn't want to try it
Thanks!
ABS Brakes
Hydraulic brake assistant-------------- early
Expanded electronic diffeential lock......... strong
Very important
Make tests (in a safe place) before and after the changes.
Comment on your experience here.
Do not forget to show me a picture of your fuse box (beneath the steering wheel) :lol:
tommytse22
Drives: polo gti
Thanks! Done the braking force and xdl! I also try copying your code the only thing work was opening all doors with one click and my warming light turn on saying my light is blown.
Is there anyway doing it Manuel turning one click unlock doors and windows close when locking car ?
Will post picture or fuse box later! My fog lights are below my headlight
I thought so, waiting for the picture of your fuse box, I'm afraid that with the original installation of your fog lights you can not activate the static cornering lights.
Read the user manual of your GTI for comfort function when opening and closing the car. :lol:
Your New coding, copy and paste in the same way.
3CB42BBF08E12400923808002D2B0CD00040410F60060000200020000000
-Make an autoscan.
-Clear all DTC's.
-Tell us the results.
tommytse22
Drives: polo gti
thank you for the help! so what does this new code actually do ?
why cant i access cental covenience mode anyway ? its not actually saying its install on the VCDs,
Read the user manual of your GTI for comfort function when opening and closing the car: what do you actually mean of this lol am i missing something out and being stupid ?
i dont really need corner with fogs to be honest! i want window automatic slowed when car is click locked and 1 click to unlock all doors now!
i ideally want more display/information on MFD but thats just asking to much really lol.
thanks for the help below is picture of my fuse box.
Summarizing:
- XDS strong and brake force ----> done
- Indicator celebration ----> done
- Seat belt warning ----> done
- Big Digital mph ----> done
- Lock and unlock all doors with 1 click ----> done
- Close windows when locking the car with 1 click ----> done. You have to hold the button of the remote control pressed during the closure of the windows. You will have an optical confimación when all windows are closed.
- Static cornering lights/fog lights----> is not possible in your GTI.
Copy and paste the last New coding for correct encoding of your Cent Elect. :wink:
To me, I also would like more information on the MFD. :lol:
tommytse22
Drives: polo gti
Oh fair enough thank you! I will copy code when I got time!
I know already that I can close window with button but I just wanted it to close when I click lock but if it's not possible then don't worry! If the one click unlock all doors is do a I'm happy :)
Any other cool vcds coding I should try out you recommend ?
Thank you
hmmm.... :!: for example:
If you want that remote control buttons work with the key in the ignition, this is your New coding:
3CB42FBF08E12400923808002D2B0CD00040410F60060000200020000000
Included and corrected the above.
tommytse22
Drives: polo gti
sweet! cheers for your help! you have been great!
