Can the heated seats be programmed to remember setting?
TheFrog
Drives: 2015 Blue GT
Post by TheFrog »
I use heated seats all the time for about 2/3 of the year, but since VW moved from the wheel-like control a few years ago to a two-setting on/off switch, I have to switch them on EVERY time I start the engine.
Is there any way they can be programmed using VAGCOM or whatever to remember the previous setting and come on automatically when I start the engine?
The good ol' days:
Re: Can the heated seats be programmed to remember setting?
I'm afraid not.
The electrical supply on the heated seats is from the fuse SB37, not through the BCM.
This is the only communication signal: T73a/36 Signal off seat heating
TheFrog
Post by TheFrog »
ciclo wrote:I'm afraid not.
Pity, but at least I know now. Thanks :)
rsmagee
Drives: BlueGT (6C)
Post by rsmagee »
Ignore, I need to work out the codeing. It can be done on a mk7 golf and therfore it should be possible on the 6C
TheFrog
Post by TheFrog »
rsmagee wrote:Ignore, I need to work out the codeing. It can be done on a mk7 golf and therfore it should be possible on the 6C
Ooh, potential good news...
Anything new on this matter?
rsmagee
Drives: BlueGT (6C)
Post by rsmagee »
I have sent the adaption maps to Ross Tech. The mk7 golf can do it, so the polo should too. Will try messing with the coding when I have some spare time.
