coilovers
fishtoasty
polopowah
- Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
well you better ask me then
im currently running the spax RSX kit at -75mm, and yes it is bloody low enough! the ride comfort is something you get use to, im on softest setting, its a little bouncy, and when u hit a bump in the road, you kind of know about it, but apart from that....
the good bits is that the car now responds so well round corners and roundabouts, its truly amazing, the car will keep going into the corner (if you have brand new rubber like me
not really much else to say
and yes you do get a lifetime guarantee
plus i recently read that Spaz are now filling their dampers with Krypton Gas, that was after i purchased mine, so all what i've put above may now be different!
anyway good luck with them if you do get them
worth the money and the looks
-Ben-
-Ben-
