13 row, 235mm, 1/2 BSP fittings. A bit dirty, but it's not dented or damaged.
This will set you back nearly £100 new, it's the most expensive part of getting an oil cooler. Or you can buy mine for £40ono and cut a good chunk of the cost of keeping your oil at the right temperature. You'll need a take-off plate and hoses to fit it.
I'm based in Cardiff, work in St Albans and I'm on the road a lot. So you're welcome to collect it, or meet me between those two, or PM me and see if I'm due to be heading anywhere near you. Quite happy to deliver it, if you're not too far off piste, or I can get it posted.
