Install RCD510 DAB into RLine?
As you may know, 6r R-Lines come with DAB as standard, so that leads me to believe that I could use the same antenna and cable from the RCD 310 DAB for the 510 and it will be plug and play- is this correct?
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Re: Install RCD510 DAB into RLine?
That is absolutly correct.
