2000 6N2 1.4 8valve cylinder cover removal
Aybesea
- Drives: Polo 9Ns 1.2 AZQ 2003 Reflex Silver
I have a oil leak on the cylinder cover in the front ,can i just take the cover off or as anything else need to be removed.ie DIS etc.I looked at some pictures but cant really tell
Re: 2000 6N2 1.4 8valve cylinder cover removal
DIS will need to be removed, other than that, cover just comes off.
Aybesea
Thanks i was not sure, did not want to start removing it and find out that the camshaft pully needed to be removed
I will double check that mind you. Leave it with me
Aybesea
OK thanks ,will continue to see if i can find any more info on this.
Aybesea
Seems that the AKK engine camshaft runs in the camshaft cover,so no camshaft bearing caps
This means that to take the cover off the cambelt tensioner needs to be slackened off first.What crap! means that to re seal the camshaft cover is going to take couple hours rather than 45mins or less if camshaft had bearing caps fitted.To me that is a backward step in the engine design.
i Though that was only on the 16V blocks....how annoying
