T5h/1 - additional wire beam?
warder
Drives: Polo 6R 2011
Post by warder »
Hi! Is there a simple way to add another beam to pin T5h/1?
I would like to do additional lighting as in this guide: https://drive.google.com/file/d/0B2nv91 ... FTMFk/view
How can I add there a new wire beam? Without soldering?
http://i60.tinypic.com/1zqdbpe.jpg
Any suggestions?
Re: T5h/1 - additional wire beam?
i would strongly recommend to solder new wires
For me (IMHO) the best way is crimping the two wires in the same terminal.
Examples:
----- click on pics
Image Image Image Image Image
In the following links you have additional information:
http://www.a4-freunde.com/showwiki.php? ... zu+gehoert (3)
http://www.uk-polos.net/view ... 90#p482495
Search with your browser: SN-48B (aliexpress.com)
I agree with ciclo that a double crimp is always the nicest solution. But fot the T5h/1, the wire is fairly tight in the bend there.
Cutting of the original terminal off shortens it by about 1 cm and then it becomes even tighter there. I'm not sure that is good on that spot, but it is good to consider a double crimp yes.
warder
Post by warder »
Ok, thanks! So I should to buy 000979129 terminal?
