Questions.
1. Can the waterways in and out of this EGR valve be blanked off, or are they essential for head cooling?
2. Does anyone here have a non-working/scrap one of these valves which would be better than what I have at the moment? (Part no is 030 131 503F)
I have a stuck EGR valve which also leaks water from the joint between the upper and lower body where the arrows are on my picture. It's definitely not coming round from the main mounting flange joint and it's getting worse.
I am planning to make and fit a blanking plate behind the valve while hoping that I can find another EGR at a sensible price before the next MOT. Has anyone else done this?
P.S. I have not even been able to track down gaskets from main dealers or anyone else.
All help gratefully received. Thanks.
(or https://www.dropbox.com/s/9eojigumg4oxurm/egr1.jpg?dl=0 if image doesn't work.)
