VCDS Services Available For VW Polo 6R/6C & Various Other VAG Group Vehicles
JIC Cracked
Post by JIC Cracked »
Hi Forum Members 8)
Based In London & Essex, can cover surrounding areas such Surrey,Kent, Buckinghamshire, Milton Keynes, Oxford for additional fuel cost :wink:
Available Weekdays & evening & Weekends.
If anyone was looking for some VCDS coding, I have a Genuine 2015 Ross-Tech Hex-Can Cable & latest VCDS software.
Can do various VCDS Tweaks such as
Needle Sweep/Staging 6R & 6C
Automatic Central Locking over 5MPH 6R
Alarm beep 6R & 6C
Automatic rain closing 6R & 6C (Light Sensor Required)
Big Speedo Display 6R & 6C (Highline Cluster Required)
Setting Fog Lights as Coming/Leaving Home & also activating the setting. 6R & 6C
Reverse Mirror Tilt 6R & 6C (Power Folding Required)
Changing XDS interaction 6R & 6C
Disable Seatbelt Warning 6R & 6C
Display the battery charge level or SOC (State Of Charge) 6C Only
Daytime Running Light deactivated 6R & 6C
Laptimer 6C Only
Many more tweaks & Coding options etc
I charge a small fee for the service, much cheaper than buying your own Genuine Ross Tech cable & much more stable than a cheap hacked far eastern copy cable.
Drop me a message on here or PM for more info :)
Mikeyander5on
Drives: VW Polo GTI 6c
Re: VCDS Services Available For VW Polo 6R/6C & Various Other VAG Group Vehicles
Post by Mikeyander5on »
I'm nowhere near you unfortunately but just a quick question my 2013 polo 1.2 tsi had a digital KM/h speedo can this be changed through Vcds to MPH not sure if my new gti will be the same
Sent from my SM-N910F using Tapatalk
So you are quite conversant with the 6R 6C BCM wrt doing things like "auto locking"? As far as I have worked out, RossTech have not completed any work on that BCM? (I'd like to be proved wrong BTW)
Edit:- "auto locking" - only 6R - I was wrong! Or was I, maybe that was part of today's edit?
dillo161
Drives: 6C Blue GT
Post by dillo161 »
Hello Mate,
I'm in Southeast London and would love to get in touch, I've sent a PM to you!
JIC Cracked wrote: Automatic rain closing 6R (Light Sensor Required)
Reverse Mirror Tilt 6R (Power Folding Required)
Hi JIC Cracked :wink: , Is this possible in all 6R BCMs?
stesummers76
Drives: 6C GTI
Post by stesummers76 »
JIC Cracked - would you be willing to advise how to do these mods, as i am in Manchester and have access to vcds
stesummers76 wrote:JIC Cracked - would you be willing to advise how to do these mods, as i am in Manchester and have access to vcds
Maybe I've got the wrong end of this stick, but, I think that you will find that JIC Cracked is offering these services in a professional manner, so I would not expect that one of his unlisted services is to train people up on the use of VCDS for free!
which sort of defies the point of a public forum. but i understand his background as well ;)
joe6
Drives: Golf Mk6 GTI (Scirocco gone) Polo 6c GTI
Post by joe6 »
There are videos around that teach you the basics. Long coding is very helpful. Always do a scan and record the original settings before changing anything!!!
iichel wrote:which sort of defies the point of a public forum. but i understand his background as well ;)
I agree with you completely, but maybe there is a need for this public forum to create a "traders" area where relevant traders can advertise their services in return for an annual subscription to the forum owner?
It does work for some other motoring forums that I "attend" - but there again that might involve the forum owner needing to carry out a lot more tasks which might not necessarily fit in with his present situation?
I'd think that creating and running one of these forums could be very satisfying, but you would need to watch out as it could quickly evolve into a very time demanding monster that takes over your life.
