Hi all,
I am new to the forum, and hoping someone may be able to help. I have a 2006 polo 1.4 tdi 9n3 which has developed a problem with the aircon. When I press the aircon button it lights up but nothing else seems to happen. The air blowing out through the vents when the ac is on is not cold so I know something is not right. I have regased the system as I thought it may have been low on gas which it was, but this has still not fixed the problem. I used my friends vag com and it showed there are a few faults which are listed below.
Address 01: Engine Labels: Redir Fail!
Part No: 045 906 019 CA
Component: 1,4l R3 EDC 0000SG 7537
Coding: 00002
Shop #: WSC 00788
VCID: 56A37BDBB24CBB8E57-4AE8
WVWZZZ9NZ6Y167768 VWZ7Z0D0879525
1 Fault Found:
17911 - Load Signal from Alternator Term. DF
P1503 - 35-10 - Implausible Signal - Intermittent
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.lbl
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H04 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002190
Shop #: WSC 00788 785 00200
VCID: 010978875B42EC3652-5140
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 10
Reset counter: 244
Mileage: 155137 km
Time Indication: 0
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Q0 820 045
Component: Klimaanlage X0840
VCID: 6ADB3F2B16340F6EE3-5140
1 Fault Found:
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 00BK BN-SG. 1S34
Coding: 09358
Shop #: WSC 00788
VCID: 3C77C9732C2041DE41-5140
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 18 AIRBAG VW51 0P 0008
Coding: 12600
Shop #: WSC 00788
VCID: 2C57F933DC40D15ED1-5140
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 903 D
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 01432
Shop #: WSC 00000
VCID: 326BE74BFE6487AE9B-5140
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0B7L GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 00788
VCID: 70EF2D4330E8F5BEAD-5140
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10110
Shop #: WSC 00000
VCID: 6FED2E3F2DD6EA46B4-5140
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 H
Component: 1N Komfortgerát 0002
Coding: 00019
Shop #: WSC 00788
VCID: 408FBD8340C8253E1D-4B00
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 6Q0 035 152 A HW: 6Q0 035 152 A
Component: Radio BVX 005 0004
Revision: 00005000 Serial number: VWZ1Z5E2997335
Coding: 0020200
VCID: 285F052398B8FD7E35-5140
1 Fault Found:
000 - -
From browsing the forum it could be the connector off the alternator which is giving the low load signal for one of the faults but I dunno.
Anyone have any ideas?
Calum
Aircon problem
Re: Aircon problem
Can you hear the air con clutch engage when you press he button?
The high pressure fault won't be helping. That can stop the system workinng
Re: Aircon problem
Thanks for your quick reply Alex. No I can't hear the clutch engage when I press the button.
Re: Aircon problem
That'll be why it doesnt get cold then. No clutch = no circulation
Run the output tests on the auto hvac system if you can and see if it passes
Re: Aircon problem
I ran measuring blocks on the HVAC system and it was showing o.o bar for refrigerant pressure, which I'm not sure why as it should have pressure in the system.
Address 08: Auto HVAC (6Q0 820 045 )
11:40:11 Group 001
14.50 V Voltage (Terminal 15)
4.20 V Fresh Air Blower (V2) Position
OFF Coolant Fan (Stage 1)
OFF Coolant Fan (Stage 2)
11:40:11 Group 002
0.0 % Compressor Load
0.0 bar Refrigerant Pressure (G65)
3.0 Comprossor Shut-Off
14.0°C Temperature (G263) Evaporator
11:40:11 Group 003
16.0°C Temperature at Floor Outlet (G192)
14.0°C Temperature at Center Outl. (G191)
14.0°C Temperature at A/C Panel (G56)
ON Heat Exchanger Deactivation
11:41:42 Group 004: Motor for Outside/Recirculated Air Flap (V154) / Potentiom. (G143)
225 Potentiom. (G143) (actual)
218 Potentiom. (G143) (specified)
218 Stop/Learned (Fresh Air)
48 Stop/Learned (Recirculated)
11:41:42 Group 005: Motor for Temperature Regulator Flap (V68) / Potentiom. (G92)
21 Potentiom. (G92) (actual)
21 Potentiom. (G92) (specified)
232 Stop/Learned (Heating)
21 Stop/Learned (Cooling)
11:41:42 Group 006
850 /min Engine Speed
ON Idle Speed Increase
0.0 km/h Vehicle Speed
Reverse OFF Reverse Gear engaged
11:42:21 Group 007
00:01 Standing Time
ON Status Terminal X
0.0 % Dimming (Terminal 58d)
OFF Auxiliary Heater (Z35)
11:42:21 Group 008
11.0°C Outside Air Temperature (G17)
55.0°C Coolant Temperature (G62)
OFF Coolant Temperat. "too High"
OFF Compressor Load Limitation
11:40:11 Group 001
11:40:11 Group 002
11:40:11 Group 003
11:41:42 Group 006
11:42:21 Group 007
00:01 Standing Time
11:42:21 Group 008
Re: Aircon problem
I ran measuring blocks on the hvac system, and it showed 0.0 bar of refrigerant pressure? The system was pressurised to the correct psi when I regased it. I will double check tomorrow what pressure it is showing.
11:40:11 Group 001
11:40:11 Group 002
11:40:11 Group 003
11:41:42 Group 006
11:42:21 Group 007
00:01 Standing Time
11:42:21 Group 008
11:40:11 Group 001
11:40:11 Group 002
11:40:11 Group 003
11:41:42 Group 006
11:42:21 Group 007
00:01 Standing Time
11:42:21 Group 008
