Yea in the 6R/6C remove the alarm sensor trim from top then you can leaver the light housing out, just be careful because until the connector is removed from the back of the light fitting there are parts of the back live, don't worry it won't touch you, it's 12 Volts. As for back just get your nails in between light and roof and pull carefully, same goes for the visor lights.
