9n3 gti gearbox
jambo91
Drives: 9n3 gti
9n3 gti gearbox
Post by jambo91 »
Hi guys,
I had a problem with my gearbox heard a rattle when idle engage clutch and it goes away. So we put it down to a release bearing so we changed that and it was still there. So the box got took out and sent away to a specialist who refurbished the gearbox and a new clutch was fitted. A lot of money has been spent in this. I got the car back and I can still here a little rattle at idle but it's very very very faint. Any ideas or is this normal activity?
jambo91
Drives: 9n3 gti
Re: 9n3 gti gearbox
Post by jambo91 »
Any one got any answers on this?
Re: 9n3 gti gearbox
Does it still go away with the clutch down?
jambo91
Drives: 9n3 gti
Re: 9n3 gti gearbox
Post by jambo91 »
alexperkins wrote:Does it still go away with the clutch down?
Yeah Alex it does go away when the clutch is down.
jambo91
Drives: 9n3 gti
Re: 9n3 gti gearbox
Post by jambo91 »
I thought forums were meant to be useful for people that were in need of help.
Re: 9n3 gti gearbox
People can only help if they can provide information on your issue. Sometimes issues are niche and take longer to get a response
If the rattle goes away with the clutch down its got to be related either to the clutch release mechanism (including arm and bearing), clutch, or the gearbox
How would you describe the noise? Like a metallic rattle or something different. Can you record the noise?
jambo91
Drives: 9n3 gti
Re: 9n3 gti gearbox
Post by jambo91 »
alexperkins wrote:People can only help if they can provide information on your issue. Sometimes issues are niche and take longer to get a response
It's a weird noise Alex, like a ticking when I got the gearbox back a new clutch was fitted and there was no noise for the first couple of days now it's slowly created back.
Re: 9n3 gti gearbox
Strange. Is it there from cold?
jambo91
Drives: 9n3 gti
Re: 9n3 gti gearbox
Post by jambo91 »
alexperkins wrote:Strange. Is it there from cold?
Yeah but can't here it cause it's idling high. When it got refurbished it got the works new diff pin, synchros, bearings and seals.
Re: 9n3 gti gearbox
I would be tempted to take it back to where did the rebuild and demonstrate the ticking to them
jambo91
Drives: 9n3 gti
Re: 9n3 gti gearbox
Post by jambo91 »
alexperkins wrote:I would be tempted to take it back to where did the rebuild and demonstrate the ticking to them
I wish I could they are 4 and a half hours away from me. It was done through the garage I got the car from!
Re: 9n3 gti gearbox
I see
Perhaps a silly question, but it was a reputable garage wasn't it - they haven't just said they did the gearbox and fobbed you off....
jambo91
Drives: 9n3 gti
Re: 9n3 gti gearbox
Post by jambo91 »
alexperkins wrote:I see
It was a specialist who does lots of VW gearboxes mate. It could well be just a gearbox chatter!
Re: 9n3 gti gearbox
Good. Just wanted to check as I know people that have had a 'garage' do the work, and it turns out they didn't do a thing!
It could well be gearbox chatter. Depends how noticeable it is really.
jambo91
Drives: 9n3 gti
Re: 9n3 gti gearbox
Post by jambo91 »
alexperkins wrote:Good. Just wanted to check as I know people that have had a 'garage' do the work, and it turns out they didn't do a thing!
It's not that noticeable tbh, but was the exact same noise I heard before the difference pin popped out and smashed the casing. Just unsure if it is just a chatter or not!
