On a 2015 GT is this just a case of removing the door rubber and pulling the trim or is it more complicated anyone know?
I want to run a cable behind to dash.
Thanks.
"A" pillar trim removal
deltalimamike
- Drives: GT TSI
Re:
it is that easy yes
deltalimamike
- Drives: GT TSI
Re: RE: Re:
Thank you.iichel wrote:it is that easy yes
deltalimamike
- Drives: GT TSI
Re: RE: Re:
Thanks. There is no airbag.rsmagee wrote:Iv done this loads of times, never needed to remove the door rubber, just pull the trim. Only time its different is if there is an airbag which will be clearly marked.
deltalimamike
- Drives: GT TSI
Re: RE: Re:
Have either of you two done this on this model?
I've tried and can't remove it.
I'm pulling/levering with as much strength as I dare put on the plastic panel and it's not budging!
- CNK
- Drives: 6R
Re:
Check out these photos: http://www.vwwatercooled.com.au/forums/ ... ost1163169
deltalimamike
- Drives: GT TSI
Re: RE: Re:
Thanks.CNK wrote:Check this photos: http://www.vwwatercooled.com.au/forums/ ... ost1163169
No idea why mine doesn't want to budge then.
