No speedo lights
No speedo lights
Hi. I got digital clock lights and heater panel lights but no lights from the two bulbs that illuminate the dials. Is There some bad ground? Illumination Wheel Is at full! And Sometimes it Comes on briefly an just cuts. .. someone know what to do?
Re: No speedo lights
Illumination wheel might need a clean - if you move it gently can you make them flicker?
Otherwise, could be a corroded connector on the back of the speedo that needs cleaning
