Hello everyone.
i have new polo 1.2 6c for 2 month now.
i decided to upgrade the look of my car and purchased Phillips DRL.
in order to install them i have to connect one cable into the car fuse box, into ACC pole (+) or KL15.
i have no idea how to find that.. or what is this pole
there is no map of fuses or something in the car manual and im lost....
does anyone have any idea or solution to me? how can i locate the correct pole.
if needed i'll add a photo of the fuse box.
thank you!
Installing DRL led on my polo
Re: Installing DRL led on my polo
Please, can you show us an image of the light switch connector of your 6C?
You can make them work perfectly in two ways, through the BCM or through a relay.
