GTI ECU Pins help needed!
andrew.graham
Post by andrew.graham »
Hi all, I need a diagram of all the pins of the GTI 6n2 ARC engine. Does such a thing exist? Cheers
Any help would be much appreciated! :)
Re: GTI ECU Pins help needed!
Not as such. It's broken down to component basis
What are you wanting to do
andrew.graham
Im engine swapping a 1.6 Gti engine into my lupo. I have a diagram for the lupo of every ecu pin with what each is so was Gonna try and just find one for the polo and it would be smooth sailing splicing the loom togetger but no luck so far.
andrew.graham
Im basically looking this but for a gti polo Image
There might be one in ELSA but i havent got access to it at the moment - one of the other guys on here should be able to get it such as Ciclo
Lupo and Polo are very similar from a wiring point of view, but there are definately a few pins that are different as ive had to move thing around before that came from the lupo forum to make it work on the polo
andrew.graham
Ok I got a hold of some current flow diagrams and I'm trying to make sense of them. Would you know what the numbers at the end of some wires mean? They don't match ecu pins and im well confused.
The sw/ge wire there ends at 28 but I have no idea what that 28 means. Same with the bl one at 107.
If anyone has an idea what these mean might help a bunch!
Cheers!
937carrera
Drives: 2000 Polo GTi
Post by 937carrera »
The numbers in square boxes are references to link to another part of the current flow diagram.
So "107" says go to the column / current flow 107. In that column you will find a box with the number of the current flow you just came from.
I'm a bit confused by your diagram. Looking at Elsa, Connection L on the alternator goes (from current flow 1) to current flow 121, not 107, are you sure that the diagram you have is for a 2000 ARC GTi ?
Hope that helps
andrew.graham
937carrera wrote:The numbers in square boxes are references to link to another part of the current flow diagram.
Hope that helps
Oops that was off my lupo diagram thats why the number is wrong but yes thanks so much for the help, it's definitely making a but more sense to me now!
