How to remove the right driver air vent?
littlemisspolo
Drives: Polo 9N3 1.4 2007 UK
Post by littlemisspolo »
I have a VW Polo 9N3. My driver air vent has snapped and I have a replacement of the whole actual thing. I need to be able to remove the whole thing to fit the old one in. Here is the part that I talk about:
I'd like to remove the old on and put this one in. Can someone please advise me?
Thank you :lol:
polo1.9TDI SPORT
Drives: Polo 1.9 Tdi Sport
Re: How to remove the right driver air vent?
Post by polo1.9TDI SPORT »
I would assume you have had the part fitted now but if not see below -
Open the drives door fully.
On the side of the dashboard usually hidden by the door you will see a small notch on the side where you place a flat head screwdriver.
pop the screwdriver in here and pop open the plastic cover (this is actually the fuse box area) The plastic cover is hinged toward the windscreen, be careful as the hinges are plastic! it may take a bit of wiggling to open it enough around the rubber door seal.
Once open you can literally push the air vent from the back and pop it out.
The topic below shows the area very well, picture 3 !!
viewtopic.php?t=52688
