oil in plug hole...
neil.hunter
oil in plug hole...
Post by neil.hunter »
Hi All,
I'm after a bit of advice, 2001 Gti and its been running a but rubbish recently. Had a fault code for the camshaft adjuster valve (17927) so a new one of those is on the way (are they pressure operated) and also a cracked coilpack so that was replaced also.
My main question is though, the plug hole nearest the cam sprockets was full of oil, none has been split and I'm reading about the gasket needing resealing with specialist sealant? Timing belt off etc etc.
Is it normal to be full of oil and how has it actually leaked into the plug hole? Also, the top of the piston seemed quite gunked up yet it's compression testing all OK at around 14-15 bar across all cylinders...
Not to mention that I appear to be having to top up the coolant once a week but a pressure test says it holding pressure all OK.. (Possible cap?)
Please, I don't need this to be head gasket... Lol
Any help appreciated...
Re: oil in plug hole...
Where was the oil. On top of the spark or in the spark plug hole?
You might have a coolant leak in the radiator or heater matrix potentially if the head gasket isn't the culprit
neil.hunter
Thanks for the reply Alex, it did appear that the oil was mainly in the plug hole (the one nearest the camshaft adjustment valve). What worried me is that the top of the piston did look a bit crappy but again I don't know if that could be unburnt fuel from the weak spark after I found out the coilpack was arcing.
Are the rad and matrix usual suspects? It is frustrating me to say the least..
I'm nearly at the point of either getting rid, or an engine change but I don't think that'll help me as I'll be wandering into the unknown again...
I wouldn't be too worried. Oil could've been spilled in there or something similar
A bit of oil on the threads too isn't uncommon.
You could chuck a bottle of radweld in to see if that stops your coolant disappearing. I've had good results with that in the past
neil.hunter
Theres the thing though, when I last put a set of plugs in, a year ago, I noticed oil in the same plug hole and cleaned it all out.
To be honest, there was quite a bit in the plug hole :-/
I'd always assumed that radweld was nasty stuff for engines and therefore avoided it like the plague..
I'm happy to try if it aint gonna do no damage?
If there's no loss of compression and you aren't losing oil it's a bit of an odd one. The head gasket might be seeping oil very lightly
It shouldn't do any damage providing you follow the instructions
Radweld Gold is a better formulation albeit I've never had any trouble with the normal radweld
937carrera
Drives: 2000 Polo GTi
Post by 937carrera »
alexperkins wrote:I wouldn't be too worried. Oil could've been spilled in there or something similar
Could the oil just be a little bit of seepage from middle of the the cam cover. Maybe just nip it down a little and then ignore ?
It could be. Not unusual for the bolts to loosen a little over time
How many miles has it done?
neil.hunter
I have to be honest, I am suspecting the cam cover myself but only from previous stories I've been reading about them leaking and how much of a pain they are to reseal (Cambelt off etc).
Would a nip down possibly sort it then, if indeed that is the culprit?
If it's a little loose a nip down might fix it
It's a Cambelt off job to remove the rocker cover as the camshafts have to be removed with it due to the fact they pass through it
neil.hunter
Cheers Gents,
I'll give it a nip down tomorrow and report back in a few days re the leakage.
Many Thanks again.
937carrera
Try to follow the rules for tightening order and use a torque wrench if you have one. It might also be worthwhile slackening all the bolts off half a turn before re-torqueing.
neil.hunter
937carrera wrote:Try to follow the rules for tightening order and use a torque wrench if you have one. It might also be worthwhile slackening all the bolts off half a turn before re-torqueing.
I'll have a look and see if the tightening sequence is on auto data, although I suspect it isn't.
Don't suppose there's a link for them? I know it's normally 10nm.. shall we say 15nm for a nip up?
937carrera
10Nm + 1/4 turn is the specification.
Having just looked in ETKA there doesn't seem to be a particular tightening order, so start in the middle and move diagonally outwards
