I need help with installation xenon headlights on Polo.
I have BCM from T5 7H0937089D and should connect these three wiring to make a circuit and make everything working properly. I followed this procedure
https://drive.google.com/file/d/0B2nv91 ... ef=2&pli=1
Is this procedure with three wires necessary only when installing the BCM from T5 or its the same when installing BCM max from same Polo?
Does anyone have part numbers of pins or repair wires that I can make that three wiring sets?
