first of all i apologise if this has already been asked, I've had a look through the forum but cannot find anything related.
I have a 6n2 1.4 16V AUA, starts fine first time, idles around 1100 RPM first thing in the morning, when the revs start to settle (usually idles around 850 when warm) to around 1050, and starts to sound very lumpy, if i leave it long enough without putting the throttle down, it will start to hesitate to the point where the revs go down to around 500-600 RPM, then would eventually cut out, but then starts up again first time!
If i rev it a few times as stated above, it won't cut out and doesn't become lumpy, when i start the car, and drive it within around a minute of starting it up, the car hesitates like it's misfiring, this only happens for around half a mile, but it doesn't throw any codes up. When the cars starts to warm up, the car runs perfect.
The code that keeps showing is P0135, which is the Manifold O2 sensor i believe? But this has been on before this issue started
I've done the following since the issue has been happening:
Service, including fuel filter and air filter, removed the throttle body and cleaned it, cleaned the airbox and ensured the oil breather was not clogged up, have changed the ignition coil, leads and plugs, Alternator and battery have also been replaced due to a non related issue, and now i'm at a dead end, so any help would be greatly appreciated.
Thanks for reading!
