Hi there, I'm new to VW and the forum, my partner has a 1999 6N polo 1.6, it has the "service" reminder coming up on the dash, I've given it a oil change and the like and want to reset the reminder.
I tried the usual Google result of switching key on then off and holding the trip reset... That never ended up working, so I bought a VAG reset box off ebay... That didn't work, so I purchased a D900 scanner tool... That doesnt work, says it can't connect.
So I Googled some more and found out I need to check the plug, 4x wires, 2x ground, 1x 12v and 1x 3.5(ish) for signal.
I have 12v, chassis ground, 3.5v signal but no signal ground.
Following the wiring it doesn't look like its been removed so it was never there?
Can I just earth the wire to chassis to get scanner to work, or will it toast the computer?
Is it normal to only have 3 wires?
Is there a way to reset the service reminder that I haven't tried?
Thanks for any help you might be able to give
Polo OBD fault
Re: Polo OBD fault
Dont go playing with the ODB plug - thats asking to damage the cars ECU in one foul swoop
Have you checked the procedure in the manual?
DvsDev
- Drives: 6N1 Polo 1.6
Re: Polo OBD fault
Dont have a manual, have ordered a Haynes book but I'm waiting on delivery
DvsDev
Re: Polo OBD fault
Never mind, Haynes manual arrived today, says late 1998 and 1999 models are non resettable and have to go to VW to reset service reminder
