wheel bearing like noise
s-gx
Drives: polo 6n2
Post by s-gx »
Hi guys, currently been experience a noise that i thought was my wheel bearing as i could hear it when turning left but not right, i have had it up on a ramp and checked for play but cannot find anything, does anyone have any ideas? im just hoping its not the gearbox!!
T.I.A :D
937carrera
Drives: 2000 Polo GTi
Re: wheel bearing like noise
Post by 937carrera »
Did you check for play in the right hand driveshaft ?
s-gx
Drives: polo 6n2
Post by s-gx »
nope i only checked for side to side and top to bottom play, whats best way to check for play in it? thanks
937carrera
Quick way is to try and rotate the driveshaft and feel if there is any significant play.
Better way is to remove the driveshaft and check for CV movement against the shaft
s-gx
Drives: polo 6n2
Post by s-gx »
Been told no excessive play in drive shaft but there is play in the UJ, would this cause a bearing like noise? Also discs and pads are low.
Sent from my HTC One mini 2 using Tapatalk
937carrera
Yes, that's it.
Technically the Polo has front driveshafts with two constant velocity joints per driveshaft.
UJ / universal joints are to my mind the the of joint fitted to propshafts on older front engine rear wheel drive cars (eg Ford Escort / Cortina)
There isn't anything to cause play in the driveshaft, except for wear in the splines that the CV joints slide onto, which I would not expect on the low power output of our Polo's. So yes, the wear in the CV joints (ball and cage construction) can cause the wear and sound you described.
They're not too expensive so I would replace, especially if the shaft has already been removed for inspection
937carrera
T25 van design, but good photos of the general design if you want to understand better
http://volksweb.relitech.com/cvjoints.htm
