Inviato utilizzando Tapatalk
Well, you could remove a wheel centre cap and read off the part numbers that are moulded into the material, or look up an on line VW group parts catalogue and check which version your car should have etc.next703 wrote:I do not understand the codes on Polo caps. How do I find the information?
The code is on the reverse side of the centre cap. If you're removing an existing cap from one of your wheels to find the code by prising it off with something like a screwdriver, be careful not to damage your wheel. Alternatively, your VW dealer should be able to tell you the centre cap code for the wheels you have on your car (assuming they are VW wheels and not an aftermarket set of wheels).next703 wrote:I do not understand the codes on Polo caps. How do I find the information?
