Ive tried playing about with the clocks but cant manage to get any sort of reading.
Can any1 suggest wot might cause this?
u can do it just without removing the steering wheelGroovyCarrot wrote:Piece of cake to change. Remove steering wheel, remove clocks, disconnect speedo from clocks (pull), trace cable to gearbox, unscrew nut, trace cable to bulkhead, mk3's screw in, mk2's just go through a rubber bung. Pull cable through into engine bay, reverse procedure with new cable.
Hope it helps
