ABS warning light/code reader
nico88uk
Drives: 1.4 MPI 2000
Post by nico88uk »
Hello again, the ABS warning light came on a few months ago on my 1.4 mpi polo, as it's due a MOT soon I'm trying to sort it out.
I got a diagnostic test which showed: Front offside ABS sensor and was quoted £90 to replace. I was going to check the fuse first and then attempt changing it my self as a replacement sensor is only £20.
Once replaced how do I reset the warning light, would a code reader like this clear it?: http://www.ebay.co.uk/itm/OBD2-VS450-Sc ... SwTZ1XmaO2
Thanks again
nico88uk
Re: ABS warning light/code reader
Post by nico88uk »
Oh also does anyone know what fuse it is for ABS, Haynes manual has fuse 8 in the passanger fusebox. But my understanding was it was located on top of the battery fusebox?
Yellow fuse on top of the fusebox
As for the sensor they frequently fail. Cheap copy ones don't fit properly though and often need sanding down to make them fit
It's not a particularly pleasant job
