For sale we have a Volkswagen T5.1 Transporter with brand new camper conversion
This is a 61 plate 2012 T28 Startline 102ps with 48554 miles
V5 has been re-classed as Motor Caravan with DVLA
MOT runs until July 2017
The vehicle came from VW on the long life service, we have just given it a full service with genuine service items, front brake pads have been replaced with receipts to prove, along with all previous service documents.
Additions to standard spec, we have added
Electric windows, Body coloured bumpers and mirror caps
Colour coded reverse parking sensors, Front badgeless grille
Brand new 18” alloy wheels with brand new tyres
Colour code front day time running lights
Clarion full European satellite navigation unit with built in Bluetooth for mobile phone connection and usb connection for iphone/android device.
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030355.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030359.jpg[/img]
The spec for the brand new camper conversion is as follows
Van was firstly fully stripped and sound deadened fully with Dynamat, it was then fully insulated over the top of this, vehicle was then fully carpeted and trimmed to the highest standard.
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030274.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030273.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030272.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030271.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030270.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030268.jpg[/img]
Fitted with SCA184 High Lift elevating roof, this is fully TUV approved with certificate included, additional room for two people to sleep in the pop top.
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030357.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030374.jpg[/img]
RIB convertible bed fitted with vehicle specific fitting kit, allowing you to carry passengers in complete safety, certificate supplied
This seat converts to create a double bed for additional sleeping area
Under the seat is stored a brand new Portapotti qube 335.
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030366.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030379.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030375.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030372.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030349.jpg[/img]
Under body water tanks are fitted to give a 48 litre fresh water storage and a 38 litre waste water storage, level gauges for both of the tanks are incorporated into the main electrics control panel.
[img width=281 height=500]http://i69.photobucket.com/albums/i69/t ... 030363.jpg[/img]
The van is fitted with a Smev 9222 combination sink and 2 burner hob with a Smev 555 grill fitted below this, these are both powered by gas, refrigeration is taken care of with the Waeco CRX50 fridge/freezer fitted along side the grill, this runs from either the secondary battery system, the gas bottle is situated in the rear metal housing. The gas system is fully tested and certified.
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030361.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030362.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030368.jpg[/img]
The electrical system is all fully fused and RCD protected using a Sargent EC155/51 system, additionally there is a 104a/H battery installed, this is charged from a split charge system, the vehicle also has a 240volt mains hook up system, when connected to the mains supply this will then run all the vehicle interior electrics and additionally charge the secondary battery.
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030371.jpg[/img]
Heating for the rear is by a Eberspacher blown hot air system, this runs from the diesel tank on the vehicle, the system is controlled from a rear mounted temperature controller and thermostat.
All windows have privacy glass installed with Van-X black out curtains fitted to each window. The window over the hob has a sliding opening window. Cab area windows have silver screens that fit perfectly to the side windows and windscreen.
The front double seat is fitted with a Kiravans double seat swivel, there are two tables, one fitted with a removable leg to the middle of the floor and additional one fitted to the near side “b” pillar on a 90 degree fitting.
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030353.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030352.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030381.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030382.jpg[/img]
All cabinetry has been made bespoke and is in Driftwood finish with grey contrasting trim.
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030364.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030365.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030369.jpg[/img]
[img width=281 height=500]http://i69.photobucket.com/albums/i69/t ... 030370.jpg[/img]
[img width=500 height=281]http://i69.photobucket.com/albums/i69/t ... 030378.jpg[/img]
Also supplied is a rear barn door awning/canopy, this is fitted around the top of the rear barn doors when opened to give some additional outside space.
[img width=500 height=280]http://i69.photobucket.com/albums/i69/t ... 0119_1.jpg[/img]
Price £26950
More pics to come
Volkswagen T5.1 Transporter with brand new camper conversion sold
Jump to
- Polo Forums
- Classifieds
- ↳ Parts For Sale
- ↳ Wheels & Tyres
- ↳ Brakes & Suspension
- ↳ Cars Breaking
- ↳ Unsorted For Sale Posts
- ↳ Cars For Sale
- ↳ Wanted
- ↳ Group Buy
- Performance & Technical
- ↳ DIY Guides
- ↳ ICE
- ↳ Chassis
- ↳ Powertrain
- ↳ Detailing / Bodywork
- ↳ Electrical
- Non-Polo Vehicles
- ↳ Seat Ibiza
- ↳ Skoda Fabia
- Polo Community
- ↳ Announcements
- ↳ Club House
- ↳ YouTube Videos
- ↳ Photography and Photoshop
- ↳ Reviews and Features
- ↳ Meetings & Events
- ↳ Meetings & Events Gallery
- ↳ Members Rides
- ↳ Was that you?
- ↳ Virtual Post Cards
- ↳ Forum Technical Help!
