☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼
WIRING LOOMS. POLO 6R. (2009-2014 Europe, and other markets -->2022).
AUTOMATIC LIGHTS.
- All wiring sold here complies with all regulations regarding Automotive Wiring.
- FULL TECH SUPPORT. "By email", from the beginning of the purchase to the end of the installation. 100%.
- Lifetime warranty.
- Place your order here or by PM.
All languages. Mainly English and Spanish, and a bit of the Romance and Germanic languages.
All other languages ​​with translator. Lots of experience, "easy" and "funny" for everyone.
Automatic lights wiring + CH/LH.
This wiring is for those with BCM Max from factory 7H0937089 B/D/F , 7H0937090 A/B/D, or BCM 6R0937088 D/F, or BCM Max 7E0937089 or 7E0937090 /B/C/D/E. RHD and LHD.
- Model Year A, B, C. 2010, 2011, 2012 .
Perfect wiring length for easy installation.
Gift: 2 Relays 646 + AUTO Light switch.
- Model Year D, E, ... etc --> other markets. 2013, 2014, ... etc --> 2022 .
Gift image:
This way, the buyer does not make a mistake in purchasing them, as has happened on several occasions over the past few years. 100% Tested ✅ 🧙‍♂️.
- 111€.
- Payment by Paypal.
- Free shipping! Registered/Certificated, with tracking number.
Note: for those living outside the EU, the buyer will be responsible for any duties, fees or taxes levied by customs in their respective countries.
In no case is any other value declared than the one stated here (wires, relays, switch = 1kit).
What do you need to have to install the automatic lights on your 6R?
1- BCM Max + Rain Light Sensor (can be retrofitted if necessary).
2- Wiring + Two relays + Auto light switch.
3- Tool Laser 3932 Terminal Tool .
4- Diagnostic tool, for coding.
- Installation guide: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
If you do not have the necessary tools/knowledge/skills/time, it is not a problem, you can have the installation done by a workshop.
- Full tech support (BCM/RLS coding, etc).
'All' lights in your 6R will work perfectly at the appropriate time, OEM way.
It is impossible to get your 6R's lights to work properly using any other method for Auto lights. (MOT, CT, TUV, ITV, etc)
- Requested information:
VCDS Autoscan. Recent.
BCM MAX.
Important note ONLY for those who need to install a BCM Max:
I no longer manufacture wiring harnesses for BCM Max adaptation, although I can help/manufacture and provide assistance with part of the wiring, ¨only the WL3¨ shown in my BCM Max installation guides (below). It is a question of weight and shipping costs, that is, if you are willing to pay the additional shipping costs, I can extend my help (WL0, WL1 and WL2). Cost clarifications by email, depending on what your 6R model requires.
E.g:
An example of my technical support:
Wiring for BCM Max adaptation.
For those with a BCM from factory 6R093708X. X=5/6/7.
You need a BCM Max (7H0937089/90x or 7E0937090x).
Adaptation.
- WL0: +30 signal.
- WL1: CAN lines.
- WL2: Fuse box - BCM.
- WL3: BCM - Light switch.
- WL4: Only if necessary. Wires for reversing light and license plate lights.
Examples:
7E0 LHD. Works like a charm. 8) http://www.uk-polos.net/viewtopic.php?f ... 06#p506893
7E0 RHD (IND). Works like a charm. 8) http://www.uk-polos.net/viewtopic.php?f ... 21#p515534
7H0 LHD. Works like a charm. 8) http://www.uk-polos.net/viewtopic.php?f ... 80#p514546
7H0 D LHD. Works like a charm. 8) viewtopic.php?f=56&t=70853&p=529913#p529529
And another large number of examples.
I will let you know which installation guide is most appropriate for your 6R.🧙‍♂️
A BCM Max will allow you to expand the equipment of your 6R.
- Automatic lights.
- Bixenon/led headlights.
- Direct TPMS.
- High Beam Assit.
- Discover Media PQ.
and others...
Before buying a new or second-hand BCM Max, ask me which one you need for your requirements. (I do not sell BCM MAX).
Pictures from:
Relay carrier
Light Switch connector
Dimmer connector
Fuse box
New BCM.
:arrow: Read this page in its entirety, it will be very useful for you.
Due to the multiple and different circumstances of the users who contact me (VW, SK, SE), I'm forced to:
Provide "personalized" technical support via email.
- Troubleshooting and coding = 30€*
Contact by PM.
*Clarifications:
- Full technical support is FREE if you purchase my wiring looms.
- My technical support also will be FREE if you start a new thread in the appropriate forum section. Please provide the requested information before asking your questions, and let me know via private message where you are asking your questions. Thanks!
BCM Max PQ25. Flash files to enhance functions. Files available.
💎Originals💎.
Contact by PM.
C
Not available.
D
Not available.
B0
Not available.
Headlight Activation, Automatic.
Automatic headlight activation ensures optimum vehicle lighting at all times, without the driver having to switch the headlights on or off manually. The system offers the driver a significant gain in terms of convenience and safety. The headlights are automatically switched on by means of a dusk sensor as darkness sets in, or when driving through a tunnel in the daytime. But the headlights are also activated in rain (continuous wipe for more than 5 seconds) or at high speed (at speeds over 140 km/h for longer than 10 seconds). When the speed drops again or the wipers are switched off, the system automatically deactivates the headlights after a short time. In this way your own vehicle is more easily seen by other road users.
Coming Home Function (semi-automatic, via High Beam lever -flash-). Leaving Home Function (automatic, via Remote).
When the occupants leave the vehicle, the dipped beam headlights, the courtesy lights in the exterior mirror housings, the tail lights and the number-plate lighting initially remain on and are switched off automatically after a delay period (coming home). The same lights are switched on when the driver unlocks the doors with the radio remote control (leaving home). In this way the car’s own outside lights help to illuminate the way to and from the door of the house whenever you arrive or set off in the dark.
-PQ25.
Coming Home function: Light switch in AUTO, ignition switch OFF, pull from HB lever -flash- once, open/-ed the driver's door, the lights will come on.
Leaving Home function: Light switch in AUTO, open the car with the Remote, the lights will come on.
olegre
Drives: 2012 GTI
Re: ☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. Light Assist. ☼
Post by olegre »
Hi!
Do you still sell this items?
I would very much like to buy a set :D
Hello olegre.
Please, you can provide me more information from your GTI.
Bixenon from factory?
Rain sensor?
VCDS Autoscan?
Fernando.
olegre
Drives: 2012 GTI
Post by olegre »
Hello, Fernando.
Thank you for your fast answer!
Is it possible to send this information via PM?
If so could you please send me a PM first, i'm new to the forum so i have this message:
"We are sorry, but you are not authorised to use this feature. You may have just registered here and may need to participate more in discussions to be able to use this feature."
-Ole
Please, check your inbox. :wink:
olegre wrote: -Ole
Hi olegre.
Because of your email request. (I contact with you here -through the forum- because I do not know if you get my emails)
Please can you send me another email address? (in case you have another). It seems that your email server is not working properly. :)
Since yesterday I sent you a lot of information.
I receive messages from my server that say the emails cannot be delivered.
Maybe you should empty the inbox of your email.
olegre
Drives: 2012 GTI
Post by olegre »
Hello.
Sorry for my late reply!
It's seems like my email server has blocked/blacklisted your email address. I have now white listed your email.
It it possible to try to resend all of your emails the last few days?
Have you gotten any of my emails, or my payment?
Thank you for clarifying!
Sorry again about the delay :(
Ah! Now I understand, ...my email server also blocks and blacklists most emails from hotmail and other email providers.
Do not worry about anything :wink: , from the first moment everything has been done with exquisite precision (like the thousands of times I did previously).
I will resend all messages again with all the valuable information you need (the same info I sent you from the first moment).
According to my calculations, you will receive the package this next week, on the terms and conditions you requested me. :wink:
Hmm ... Paypal also have provided you with all the shipping details, check that your mail server does not have Paypal blacklisted. :lol: (it's a joke)
Thanks to you. 8)
Fernando
olegre
Drives: 2012 GTI
Post by olegre »
I just received and installed the auto light, and it works perfectly!
I have to say this has been one of the best purchase over internet I have ever experienced. The customer service that I got from “Ciclo” is by far the best. I had some trouble with my email spam filter, it was set to too strong (totally my fault). After whitelisting the email, Ciclo resented all of the email from start.
The level of detail in the installation guide was perfect as I’m used to work in a office and not on cars :lol:
Thank you Ciclo for all of your help!
Thanks to you, it was a great pleasure to deal with you.
I'm here for whatever you need. :wink:
Asi2191
Drives: SE 1.0L
Post by Asi2191 »
ciclo wrote:Thanks to you, it was a great pleasure to deal with you.
I am interested in a couple of things, can you please PM me to discuss.
I would like auto headlights, auto washer, gas bonnet strut and some more. I have a 6C 2016, 1,0L MPI.
Looking forward getting your PM
graaja
Drives: Polo GT TSi
Post by graaja »
I got the BCM Max + Auto headlights, CH/LH wiring set from ciclo and was able to successfully complete the installation. I have documented the installation in the below link.
viewtopic.php?f=56&t=69121&start=75#p519164
And a couple of videos in the below link.
viewtopic.php?f=56&t=69121&start=90#p519380
ciclo's support was phenomenal. The wiring looms were of very high quality. He prepared an extensive PDF document with very clear pictures of each wire set and instructions of where each pin should be connected. He also provided very good support email. It was because of this exceptional quality and support, I was able to complete this installation.
Thank you ciclo for making this project a success!
Asi2191 wrote: I am interested in a couple of things, can you please PM me to discuss.
Hi, thanks for your interest in my wiring, but, this sale is only for 6R.
Polo 6R and 6C are very different.
Thanks again.
Thanks to you. :wink:
antardaksh04
Drives: TSI
Post by antardaksh04 »
ciclo wrote: B- Wiring for BCM Max adaptation + Automatic Lights Wiring + CH/LH.*
You need a BCM Max (7H0 or 7E0), Light Switch AUTO, Rain Light Sensor.
Hi Fernando,
I might have already asked several questions about the wiring harness but need help with some more questions. I have already purchased pins and connector for Auto headlight switch. However I need your guidance/help with the wiring.
I have created new topic and will add details requested by you.
viewtopic.php?f=56&t=69687
If I am not able to make wiring myself then I will request for your help in making the wiring.
Regards.
