Hi Everyone, I am thinking about upgrading my standard RCD310 to a RCD510 unit! My question is will the Multifunction steering wheel buttons still work and has anybody done this before and is it a relatively easy swap over job? Haven't really got time to be re-wiring.
Thanks Cam.
RCD310 to RCD510
Re: RCD310 to RCD510
Yes but it might need some VCDS coding
It should be a straight swap however
yes and the RCD510 had two FM antennas as opposed to the single antenna on RCD310
CGreen98
- Drives: Polo 1.6 TDI SEL
Hmm thanks guys, I really want one but don't want to waste £250 on a stereo I can't use...[emoji31] I think I might remove the RCD310 and check the connections.
So here's what I've gathered:
The normal 310 I have looks like this:
And then the bit that confuses me, there's 2 different RCD510's! One the same as mine and one with a strange yellow port?
From what I've read there's a Bosch one made in Portugal for the earlier cars and then a Delphi (or something like that) one that was made in China for the later cars. Seeming as mine is an earlyish 2011 maybe the Bosch would work better?
joe6
This link will help with identifying the RCD510 connections http://workshop-manuals.com/volkswagen/ ... t;rcd_510/
The yellow plug is for a reverse camera
CGreen98
Thanks guys I ordered one without the yellow plug anyways. Hopefully won't have any issues and will update once it's in!
