Page 1 of 2
Light Switch questions.
Posted: Wed Jan 18, 2017 12:40 pm
by haflidij
Hey there im about to put my new R20 bumper on my polo 6R but i have a few questions regarding the ligh switch that is standard on my car.
My car didnt come with any front fogs so i have a few questions.
I currently have the switch with only the rear fog light option.
Question number
1.Do i need a new switch for the front fog lights to work that come with the new R20 bumper ?.
2. If i do, what switch do i want to buy ?.
3. Any partnumbers that i need to know when looking ?.
Also would be great if you guys could link me a switch :)
Thanks for reading. :D
Re: Light Switch questions.
Posted: Wed Jan 18, 2017 12:58 pm
by iichel
Do i need a new switch for the front fog lights to work that come with the new R20 bumper ?. --> Yes
If i do, what switch do i want to buy ? --> one that supports front and rear fogs
Any partnumbers that i need to know when looking ? --> 6R0941531G probably, but depends on your daytime running lights.
Posted: Wed Jan 18, 2017 1:32 pm
by haflidij
iichel wrote:Do i need a new switch for the front fog lights to work that come with the new R20 bumper ?. --> Yes
Nice thank you for answering so quickly.
I have just the standard headlights the H7 if i remember correctly. I found few but i only found one on ebay that has that exact part number with the G in the end. Most of them end with J. If i would buy one that doesnt end with a G is it likely it wont work ?.
Posted: Wed Jan 18, 2017 3:19 pm
by iichel
Dipped beam as DRL --> J
No dipped beam but lights in bumper as DRL --> G
Posted: Wed Jan 18, 2017 3:20 pm
by haflidij
iichel wrote:Dipped beam as DRL --> J
Im such a noob in this ... Is there any chance that you could find one that is new that would work for me ?.
Would be a crazy nice thing of you :D
Posted: Wed Jan 18, 2017 5:34 pm
by iichel
if you start you car and set the light switch to 0, what lights are turned on at the front?
Posted: Thu Jan 19, 2017 1:25 am
by haflidij
iichel wrote:if you start you car and set the light switch to 0, what lights are turned on at the front?
The two main headlights with the H7 bulb.
Ill show you a photo of them so you can see.
But when the switch is on O the small W5W bulbs are on.
https://postimg.org/image/pujuqkth5/
Posted: Thu Jan 19, 2017 6:05 am
by iichel
To maintain your current configuration and add fog lights, get the one with J at the end
Posted: Thu Jan 19, 2017 6:08 am
by haflidij
iichel wrote:To maintain your current configuration and add fog lights, get the one with J at the end
Hey sorry i was going to say when you have the switch at O the headlights are on as you see on the photo i added. Not the W5W bulbs. I got confused for a sec.
I found this one but it seems a bit steep of a prize. Is this normal prize ?.
And would this one work ?.
https://postimg.org/image/k2oz31r7h/
https://postimg.org/image/hmn5p794t/
Posted: Thu Jan 19, 2017 12:35 pm
by haflidij
Ciclo
@iichel @ciclo
I can be safe by ordering the version that ends with J ?.
Thinking about ordering it now then :)
Posted: Thu Jan 19, 2017 12:42 pm
by iichel
yes that one is fine.
Posted: Thu Jan 19, 2017 2:06 pm
by haflidij
iichel wrote:yes that one is fine.
Big thanks for answering me all the way through :) Appreacite it alot. I will go ahead and order it now.
Also one final question... :D
I dont need any wiring ?. Its a plug and play ?.
I didnt get any wiring with the fog lights but i can probably just buy some wires at the store and connect them with the new switch. Am i right ?.
Posted: Thu Jan 19, 2017 2:33 pm
by iichel
It will not be plug and play. You need run wires.
Dependent on your equipment:
Option A with cornering lights, your BCM needs to support this
- One wire from Fuse 57 to BCM, white plug, position 11. Fuse value is 15A
- One wire from BCM, white plug, position 9 to the left fog light
- One wire from BCM, white plug, position 10 to the right fog light
- One mass wire for each fog light
Activation via VCDS is necessary: byte 12 bit 6 to 1, byte 21 bit 2, 3 and 7 set to 1.
Option B, simple fog lights without cornering light function
- One wire from Light switch pin 8 to Fuse 54, first hole
- One wire from Fuse 54 to each fog light. Fuse value is 15A
This needs not to be activated with VCDS.
You'll might not know how to do this. If you are not sure, it would be wise to go to an expert.
Posted: Thu Jan 19, 2017 6:04 pm
by joe6
You can pick up a light switch on ebay for about £10.00 - same as the golf mk5/6.
Posted: Fri Jan 20, 2017 1:26 am
by haflidij
joe6 wrote:You can pick up a light switch on ebay for about £10.00 - same as the golf mk5/6.
Hmm. Could you link one then ?. I cant seem to find any new switches lower than 40 Pounds.
the term i look for was light switch polo 6r (part number).
