Just bought my first car and looking to get some advice on lowering springs and alloys.
Ideally after a 30-40mm drop with 15inch alloys.
Will 15inch ET45 6J wide alloys with a 30-40mm drop rub on the arches??
Cheers in advance
2001 6N2 1.4
Re: 2001 6N2 1.4
They should fit ok on that ET
Re: 2001 6N2 1.4
Thanksalexperkins wrote:They should fit ok on that ET
- Mighty_Lad
- Drives: 6n2 1.4 MPI 44kw
Re: 2001 6N2 1.4
Piggy backing on the thread here.
Could anyone tell me what Id need to get a good fit for alloys?
Pretty new here, so I dont know what ET means ect
Re: 2001 6N2 1.4
You’ll need 4x100 PCD 57.1 center bore an ET between 30-45 for a decent fit
- Mighty_Lad
Re: 2001 6N2 1.4
Appreciate that, Thanks!alexperkins wrote: Sun Aug 20, 2017 7:46 pm You’ll need 4x100 PCD 57.1 center bore an ET between 30-45 for a decent fit
What kind of tyre size would I need for a solid fit on a 15" Alloy??
Re: 2001 6N2 1.4
195/45/15 for a 6N2
- Mighty_Lad
Re: 2001 6N2 1.4
Thanks again bud
- Mighty_Lad
Re: 2001 6N2 1.4
alexperkins,
Could you recommend a place to get some alloys?
Im having bad luck with the googling here. Just getting gumtree ads.
Re: 2001 6N2 1.4
Depends what you are after mate
Rimstyle or wheelbase are good starting points. They do loads of different wheels
