Scirocco seats in a polo 6r?
mattykenny27
- Drives: 6R
Does anybody know if scirocco seats will fit into a polo 6r 2012? And is there much work required?
Willni
- Drives: Polo '14 6R, Golf 07' Edition 30
Re: Scirocco seats in a polo 6r?
Probably could but would require a lot of work with the Polo you have a choice from Audi A1 and Skoda Fabia for straight fit. Apparently Passat CC seats go in but I'm not sure on fitment
mattykenny27
- Drives: 6R
Thank you, gonna look into it cheers
Forum member D7VXD has fitted mk6 Golf GTI seats in their Polo 6r and I suspect the Scirocco seats are a similar size to the mk6 Golf GTI seats, although a different design.
Might be worth sending them a pm to find out more on what was involved in the seat swap.
viewtopic.php?f=56&t=69554&start=15
mattykenny27
- Drives: 6R
Thanks for the help, might be worth a try messaging him thank you!
Bit late but...
Reckon you'd need custom rails for the front seats or you can try measure it up and modify the seat rails yourself (a lot of hassle to get it to finally fit).
I'm not sure about how the rear bench would sit but I know the golf one isn't a straight swap either.
Also connections to the loom for the airbags etc may be different, I've placed a resistor in my loom to remove the airbag light but it means the airbags in the seats won't deploy if I crashed.
So to answer the question, yes it can be done. Although it will cost a bit extra money depending on the route you take and it'll unfortunely not be as simple as unbolting your old seats and bolting in the new ones
mattykenny27
- Drives: 6R
Only seeing this now mate sorry! Cheers for the adviceD7VXD wrote: Wed Jun 14, 2017 10:56 pm Bit late but...![]()
So to answer the question, yes it can be done. Although it will cost a bit extra money depending on the route you take and it'll unfortunely not be as simple as unbolting your old seats and bolting in the new ones![]()
