Where to find earth point in roof wiring harness
Eduard
Drives: 6C
Post by Eduard »
Hello ! I have quite a dumb question ... but, since i've watched the ross tech diagram explanation videos, I've been left with the idea that earth connections are most common found as studs.
Now I have this Polo 6C, and I need to get a wire to the earth connection 347 ( roof wiring harness ). I'm a bit confused, where do I find this ? Obviously in the roof wiring harness but... how do I connect it after I find it ? Is it like .. a wire ? Since I only know about studs. Look at the following schema:
I need to conenct my 2nd slot wire from the Rain Light Sensor to the 347 earth point ... any clues ? Any picture of a similar situation would be great ...
Re: Where to find earth point in roof wiring harness
Just connect it to any brown (and only brown) wire in the roof harness. The earth connection (horizontal line) is simply a connection from 2 (or more) wires to one.
Eduard
Drives: 6C
Post by Eduard »
Oh. Now I feel embarassed :oops:
Thanks for the heads up!
