Just after some info and sizings from the community.
Looking to do some servicing on the car, namely oil change and plugs to start with. Theres lots of information online but alot seems to refer to the older spec polos.
1 - spark plug spanner size? Is it 16mm?
2 - coil removal tool? Is it - t10094a?
3 - Litres of oil needed - guessing about 4? (If i buy a 5l i will be OK)
4 - spark plug numbers? (NGK)
5 - adaptor size needed to remove oil filter? (I read 42mm but could be totally wrong?)
6 - oil filter part no?
Would prefer to use genuine VW parts where possible vut NGK is fine for the plugs.
If there is a bible / guide somewhere for my model of car then i would be happy to be linked to it?
